How do I add external font style to the widget Text in Thingworx studio.
I have tried this:
font-family: Montserrat;
src: url(#{resources}/Uploaded/Montserrat-Light.otf);
But it is not working.
Desai
You can do this through CSS.
If your font is available on-line, then you don't need to upload the font as a resource. Just change the source URL in the CSS definition to point to the on-line copy.
Hope this helps.
Allan
Yes, you can reference your font through a CSS Style definition. I've tried it with a WOFF font and it works fine.
Now your label will use the font.
If the font is available on-line, then you don't even need to upload the font as a resource. Just change the URL in the CSS definition to point to the online version.
Hope this helps.
Allan
Hope this helps.
Allan
The CSS doesn't seem like working for non administrator users who have only run time permissions. Got any thoughts on this?
