How to change a color of toggle widget?
yhwan
Hi
A default color of toggle widget is red.
like this..
I tried to change it, but I couldn't do it.
I referenced here. https://codepen.io/Bradley_Lancaster/pen/jPzEbz
If it is possible, please give me an idea.
Thanks.
mneumann
(To:yhwan)
the toggle has basically two properties.
I've assigned the "ToggleMe" class to the Toggle Widget to control it's background color and the font color. The style sheet like this:
.ToggleMe {
  color: #2379FF;
  background-color: transparent;
For the actual background you can use
.toggle.toggle-assertive input:checked + .track {
    border-color: green;
    background-color: green;
Despite it's being a bit too green, it works quite nice.
One controls the actual track color, the other the border around the Widget.
(It will be for ALL Toggle Widgets you're using though)
I hope that helps
Cheers
/Michael
mneumann
(To:yhwan)
.ToggleMe {
  color: #2379FF;
I hope that helps
Cheers
/Michael
