9-Granite
Jul 18, 2022 11:43 AM UTC
How to connect thingworx and vuforia server
Hi community,
how to connect thingworx and vuforia? And how to check installation of experience service is done or not? I followed this doc: https://support.ptc.com/help/vuforia/es_install/en/#page/ES_Install_Help_Center%2FThingServerInstall_ESInstall_Windows.html%23
Only configuration parameter part(Step 13), I was not able to understand. So, I didn't do this. If anyone know about this please help me.
Aug 9, 2022 8:48 AM UTC
About the point 13, we have seen it, in another thread:
https://community.ptc.com/t5/Vuforia-Studio/Installation-of-experience-service-on-windows/m-p/807434
About your question, how to know if Vuforia Experience Service installation is done.
At the end of install, we have a successful message.
In a such case, we know that the connection with ThingWorx should be fine .
To be sure, in the folder where is installed Vuforia Experience Service, in sub folder bin, in a command prompt, run start-es.bat file.
In a web browser, open a new tab and access to Vuforia Experience Service URL who has this format :
http<s>://<FQDN>:<port>/ExperienceService/ping
Replace strings between <> by right values for your environment.
An OK should be displayed in web page.
Best regards,
Samuel
9-Granite
Aug 9, 2022 12:31 PM UTC
Hi @sdidier ,
I have completed installation of experience service. Now, I want change server details in installation. Can you please tell me how should I do this? Can I change server details manually in configuration.json file? Is it possible to do this manually?
Thanks.
BR,
Nilam
Aug 9, 2022 12:34 PM UTC
Hello Nilam,
Yes it is possible.
  1. Shutdown Vuforia Experience Service
  2. Backup configuration.json file
  3. Edit it in a text editor
  4. Check json format with online checker as https://jsonformatter.curiousconcept.com/
  5. Restart Vuforia Experience Service
  6. Check output in console prompt to see if an error is reported
Best regards,
Samuel
