Hello PTC Community!
Please advise a solution for creating breadcrumbs that have links to different level views.
Example: Home../View1..../View2...../View3
Thank you!
You could provide published Experience URL using the url widget.
place you widgets as breadcrumbs and set the url to each published experience. When a user clicks on the link they will be taken to the experience inside the view app.
Assuming I understand the question correctly
Hi @IB_10645210 ,
no sure what is exactly required here. Where should be the bread.
So what I suspect ->You have a picture and on mobile you want to scann it and to click on it (or something like ) then you want to be able to click the different " Bread crumbs" to open specific experience , right? Or you mean different pictures which you need to select.
Important is to clarify
Could you, please, clarify ! Thanks
Hi @RolandRaytchev Roland, Thank you for response.
Sorry for the confusion. The "breadcrumbs" is a UI element:https://www.nngroup.com/articles/breadcrumbs/
I want to link multiple views from different projects in a "breadcrumb" on top of each 2D view.
Please advise any solution:)
