Based on the solution given here I have verified that the Thingworx thing for this tutorial does exist and can be seen in Vuforia Studio. However, I have not been able to get to the Thingworx Composer application to find the application key that has been created (per instructions here). Any help would be greatly appreciated.
Thanks.
Hello rsloma,
In trial instance, users don't have Administrator permissions.
So, AppKeys menu is not visible.
I think that an URL to check with an URL if an Appkey exists or not will be blocked also without an Administrator account.
But by trying to access to a Thing with an Appkey like parameter, if access is successful, so Appkey value is correct.
Please see this thread and run a similar HTTP query in Postman:
Best regards,
Samuel
I can't use the process in the suggested thread since I don't know the URL or the application key. The following are what I know and don't know about the Thingworx composer URL for my Vuforia Studio experience service: https://<"I know this">.<"What goes here?">.<'Still thingworx.io?">:8443/Thingworx. Then I need to know how to find the application key for the Raspberry Pi thing.
Thanks.
or
It will help to find the URL.
Best regards,
Samuel
So, you Thingworx instance is : https://twx.studio-trial.vuforia.io/Thingworx
Best regards,
Samuel
