I'm stuck with the Raspberry Pi Tutorial in Thingworx Composer
Hello Community,
yesterday I tried to do the Raspberry Pi Tutorial with my Vuforia Studio Trial-Account and so far everything worked fine beside the fact that I am not able to create an Application Key or anything else in the Thingworx Composer because I can't set my permissions to anything else than Read-Only.
Is there anyone who got the same problem and managed to solve it or just completed the Raspberry Pi Tutorial with a Trial-Account as well?
Within the composer there's already a pre-created Raspberry Pi Thing and Thing Template which have all the needed Properties but somehow the Values don't change when I run the script on my Pi.
So it's either me who does something wrong or I need the Permissions to create a new Application Key and a Thing by myself.
Thank you in advance for any help.
DanielPiAnswer
I actually found an answer!
Since 2018 the instances were changed and Trial-Accounts don't have Admin-Rights anymore.
For the Tutorials there are pre-created Things and Thing-Templates and an Application-Key as well.
For the Raspberry Pi Tutorial it is necessary to use quotation marks for the "Thing(xxxx)" as seen within the image below:
DanielPi1-VisitorAuthorAnswer
