How to implement <TML Text> Widget in ThingWorx Studio?
framirezsalaman
Hi All,
Somebody knows how to implement <TML Text> widget in Thingworx Studio?
Thanks.
6 REPLIES 6
I also couldn't find any documentation on using TML Text widget.
Can somebody informed share some hints, please.
I'm interested, too.
Hej Fabio,
it's a widget to implement new xTML code - it opens unlimited possibilities - feature adding but also to destroy the experience.
You could for example insert new shaders, change tracking mechanisms etc etc....
Not documented for end customers for sure.
If you are missing a concrete feature, please feel free to ask.
Martin
Fabio Alexander Ramirez SalamancaAlessio TentiDmitry Tsarev
Just to add to what Martin's comment with additional information.
This is an advanced widget, and is one where upgrade issues may result since the TML used inside some of the widgets may change.
At the moment we are still work in progress with this widget and do not have full support availability on this widget for various reasons.
For advanced users, the TML can often be found in the dist/ folder for existing widgets.It can also contain any HTML.
Note: Usage of this widget may require upgrade help in the future and possibility of running into issue during Studio upgrade.
-Durgesh
sdall'asta
(To:dupatel)
Hi, there are news about implementation of TML text widget? Where I can found an example or any type of documentations? Thanks
Ok, thank you all for the answer!
