I want to change parameter values in the app made in vuforia studio. How do I send values from vuforia to the thingwors platform?
thank you
Have you applied the Run time permissions for the es-public-access user to the properties, events and services of the entity?
Hi @lundha ,
I see that you would like to update the Thing property in ThingWorx through Vuforia Studio. One simple example could be as follows:
Hope this helps!
Hi @ytella,
Your solution worked fine as long as we used preview, but once we tried to do it on the iPad with Vuforia View the thingworx property does not seem to update.
We preform the same actions in both preview and in the Vuforia View app so i find it strange that the first updates the property and the latter doesnt.
Any suggestions to fix this?
This worked, thanks.
