Invoke Model Service
A_Macierzynski
I just wanted to ask if there is any possibility to invoke a service on specific Model in AR scene like Play?
Or maybe there is tricky workaround for this? I spend some time and couldn't find any solution.
Adam
I tried "$scope.view.wdg['model-1'].play();" in js, the sequence played for once and didn't work after that. Not sure if it is supported.
A_Macierzynski
(To:katte)
Hello giri,
It is nor working for me unfortunately.
I tried to make tricky workaround also. I've added Slider to 2d layout. Than in code i was changing value on this slider.
I thoght that the Value Changed event can handle the change from code and invoke play on model by simple binding Value Changed -> Play. I made some test, but this is not working also. Animation is played only when I am changing the value of slider by clicking on the dot and moving it to the left or right.
Maybe you know than how to invoke Click event on button in scene? I tried few times, but without success also.
Adam
This is a good idea. Thats what I have also tried but I dont know how to trigger the click event now.
