Is there a way to import a Vuforia Object Scanner into a Vuforia Studio App?
alcubierre
I see that Vuforia Object Scanner can be used to build model targets (https://library-archive.vuforia.com/articles/Training/Vuforia-Object-Scanner-Users-Guide.html)  for Vuforia Engine (Unity).
Is there a way to import those objects into a Vuforia Studio app?
Any alternatives?
It is specific to Vuforia Engine.
As alternative, any 3D scanner can be used.
The main problem is to convert 3D Model scanned into a 3D format supported by Vuforia Studio.
Here 2 solutions :
        1. Using software of 3D scanner who has the right file format
        Or
        2. Import 3D Model file from 3D scanner into Creo Parametric and convert it into pvz file format.
             Creo Parametric supports many 3D formats to import.
Best regards,
Samuel
Here 2 solutions :
        Or
Best regards,
Samuel
