Hi Everyone,
Good Morning,
We have Vuforia Studio on Prem solution.
May I know what is the minimum internet speed required to execute the experience on Vuforia View smoothly. Also the data is being sent to ThingWorx from Vuforia Studio.
Aditya Gupta
Hi @Aditya1702 ,
I checked but I could not find a general recommendation from R&D regarding that. So I think, the general statement is to have acceptable display and download the time.
when you scan an experience:
- you need first to download it. That is one time on the start required and the loading time is depending on the Internet speed. So you could approximately calculate the time you need for download of experience with particular size depending to the available internet speed rate.
-when the experience is tagged as Allow download for offline viewing - then you can call an experience in offline mode - it will be called locally and it will not use Internet, so that Internet speed is not relevant in that case
-Runtime behavior is different and depends on the implementation
Therefore, I do not think that question could not be answered generally without considering of the specific application design.
Possibly somebody else could share his/her experience regarding to relation between Internet speed to the performance of the project - depending on the specific application requirements. Thanks
Hi @RolandRaytchev ,
Thank you for your reply.
We are inspecting automotive parts using Vuforia View & there are around 50 to 250 checkpoints/steps for a each part(one Vuforia Studio experience for one part).
For eg. If a part has 50 checkpoints/steps then status of each checkpoint/step whether it is PASS/FAIL, image captured of that particular checkpoint/step, along with the user details who is inspecting the part is being sent to ThingWorx.
Also to trigger the experience we are using AMT(Advance Model Target) which was taking time to initiate the experience or which the AMT sometimes wasn't triggering at all.
Hence, I doubted whether it is the issue related to internet speed.
Hello @Aditya1702,
It looks like you have a response on your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
