Model Size in Vuforia View
Aditya1702
I published an experience with very large dimension model in Vuforia Studio which on viewing the experience on Vuforia View used to give very large model so, every time after launching the experience I need to scale down the model through pinch action of spatial target. I again published the same experience in Vuforia Studio by reducing the scale of the model to 0.2 which was 1 earlier, still the model size was large after viewing the experience through Vuforia View.
Can anyone help me out with this.
Thanks in advance,
Aditya Gupta.
Hi @Aditya1702 ,
so means that setting of the model Widget scale property to scaled down your model does not make a difference , right?
Another option is to scale the model in the cad autoring applcaiton or in Creo Illustrate
Hi @RolandRaytchev ,
Yes, scale property to scale down the model does not make a difference. I will try to reduce the scale in Creo Illustrate,
Thanks for your help.
Aditya Gupta.
