Not able to connect to Experience Service on my mobile
priyag17
7-Bedrock
I cannot connect to Experience Service on my mobile.
I've installed Experience Service on Premise with no SSL and not registered in the GXI.
I can set and validated Experience Service in thingworx studio Info.
Also can preview and can call services of things that I made in thingworx core.
After I published this project and check with mobile connected to same network, the experience doesn't load.
I have set the exact same URL for Experience Service as I set in thingworx studio.
Then I check with chrome in mobile with ping to Experience Service (https://xxx:2019/ExperienceService/ping), got errorcode.
I am able to access ThingWorx core installed on same machine from mobile but not experience service.
dupatel
(To:priyag17)
@priyag17  What error code did you received while accessing the Experience Service(ES) URL from mobile? Please validate that ES URL & PORT (i.e. 2019) is reachable /accessible from the external system.  Is there any error logged on the ES terminal related to the issue?
-Durgesh
yanchen
(To:priyag17)
If no SSL, you should validate ES URL with " http://xxx:2019/ExperienceService/ping" there is no https of the protocol.
@yanchen yes I am trying http only by mistake posted https.
yanchen
(To:priyag17)
Just as @dupatel mentioned, can you successfully validate ES in your PC(with http://<ES host>:<port>/ExperienceService/ping)? And is there any error message that post to ES log?
