This is in reference to Fundamentals of AR course. I am not able to import RobotArmEntities.xml in ThingWorx associated with trial Vuforia Studio. However, even though the TWX project contains the RobotArm1 thing, there is no RobotArmSimulator (Timer) Thing. And since I don't have admin rights, I can't create it. Any ideas on how I can get live simulated data into the IoT Robot Arm Repair experience in this tutorial?
@priyag17 With Studio Trial account, one cannot create or import entities due to restrictions. I believe you can only see/play around with entities & data preconfigured with trail account provisioning.
-Durgesh
@priyag17 So, you are having an on-premise Experience service which is configured with your local ThingWorx instance. Now, when you are pointing ES URL inside Vuforia Studio application it is giving error. Correct?
So, are you able to validate ES URL from within Studio application? Also, check if there are any errors in Studio application logs or Experience service terminal command console. There could be an issue with your ES & TWX configuration or connectivity.
In case you have a proxy server then you might have to put the proxy details within Studio application.
-Durgesh
