Not able to view preview
vivekse
As soon as I enter code in Home.js in my project, I am not able to view preview of my project. The code is:
var ydelta = 0;
$scope.$apply(function(){
$scope.app.params.ypos = Math.max(0.045, $scope.app.params.ypos + ydelta);
$scope.goDown = function() { ydelta = -0.005; }
any help will be appreciated.
Hello @vivekse ,
there are 2 question:
Why do you need the call apply call here. So remember the defintion:
"$scope.$apply() function takes a function as parameter which is executed, and after that $scope.$digest() is called
internally. That makes it easier for you to make sure that all watches are checked, and thus all data bindings refreshed.
Here is an $apply() example:
$scope.$apply(function() {
$scope.data.myVar = "Another value";
The function passed to the $apply() function as parameter will change the value of $scope.data.myVar. When the
function exits AngularJS will call the $scope.$digest() function so all watches are checked for changes in the watched
values."
If you want to update you can use any function call and then call $digest.
think calling the $apply before the studio is initialized will always lead to error.
This will lead  to the second problem that you Preview is not displayed properly. So, I believe when you open the chrome  console window (Strg-Shift-I) you will see some error like ...Error: [$rootScope:inprog]...
If you use e.g. the following code it should work as intented:
var ydelta = 0.1;
$scope.$on('$ionicView.afterEnter', function()  {
  console.info("$scope.$apply funciton");
  if(isNaN(parseFloat($scope.app.params.ypos))) $scope.app.params.ypos='0';
  console.log(" ydelta=", ydelta)
  $scope.app.params.ypos = Math.max(0.045, parseFloat($scope.app.params.ypos)+ydelta );
So tested and it worked. I  also binded the parameter ypos to a label widget and it was updated properly :
Hello @vivekse ,
values."
var ydelta = 0.1;
