PDF Viewer Extension not working
AlexK
Dear community
I've noticed that the PDF Viewer Extension does not work any more.
Attached is the extension file that I am using.
Thanks for your help!
Best wishes
Alex
Hi @AlexK ,
I will check this. So, far this should be an issue for mobile, right? because for eyewear device- is supported via the 3D document /according to the Vuforis Studio help
So far I know there are 2 different versions of this extension to downlaod
Download 1.) PDF extension 0.3 version  (Tested on Vuforia 8.5.x and 9.0.0) or the newer one 2.) PDF extension 0.5.1 version  (the old PDF 0.3 version does not work since 9.0.x.a the new 0.5.1 version works on later versions according to a statement of TS team and I  just received a feedback  which confirmed  that it worked on  9.16 on iOS -  with simple test proejct)
What version did you use and what of mobile platfrom? Thanks
Hi @AlexK ,
AlexK
(To:RolandRaytchev)
Hi Roland,
Thanks, it works with 0.5.1!
Best wishes
Alex
HI, @RolandRaytchev
I had try PDF extension 0.5.1 on iOS18.1.1 by Vuforia Studio 9.19.11.0.
That is completely good works.
So , I don't want to show my user for print and download button in PDF Viewer by this extension.
But can be use zoom function.
Do you have a any solution ?
