Problem with Model Target optimization
ZL_9884170
As per this thread, similar issue:
I used the same method you mentioned, but I have encountered a problem: the model of entire assembly cannot completely coincide with the actual assembly. How can I solve this problem?
(The ratio of the model and the actual object is exactly consistent)
will u please elaborate it much by share more pictures with different views?
"which part" is used for model target? what's its color?
from current picture I m not sure what may be issue.
