Publishing failed: 413 Request Entity Too Large
DF_9703795
Hi everyone,
i want to publish a HoloLense Experience with some Thingworx Data, but i get this error in the studio.log file:
Why does it occur? 68MB shouldn't be too large for publishing?
Thank you very much!
6 REPLIES 6
It seems an error return by an nginx server.
So, I have a question :
  •   Where is located the Vuforia Experience Service ?
    • Is it a trial instance or an instance hosted at PTC Cloud or an on-Premise ?
Thanks in advance for your feedback.
Best regards,
Samuel
It is an on Premise Server
Try to publish again and look in Vuforia Experience Service log file.
  • If an error is thrown, it is an issue in Vuforia Experience Service
  • If no error or no verbose related to this Project, it is needed to check if an Nginx server is redirecting HTTP requests between Vuforia Studio to Vuforia Experience Service.
  • If it is correct, check log files in Nginx.
Best regards,
Samuel
sorry, but where do I find the Vuforia Experience Service log file?
It depends how Vuforia Experience Service has been setup on the server.
  1. If it rans manually in a console or a terminal, all verbose is displayed in this window
  2. If it is a service, a redirection might be have been setup to redirect all verbose into a text file.
So, the questions are :
  • Does the Vuforia Experience Service is running with a service?
  • In which Operating System (Windows or Linux) ?
Best regards,
Samuel
Okey, I will talk to the person, who is responsible for the server and if I know anything more I will come back to you.
Thanks for your help!
