I was curious whether it is possible to query some basic information from an AR experience service in Thingworx. Basically, I'd like to be able to call a service in Thingworx that returns some information on the AR experiences that have been published to an experience service on the same server. Would it be possible to get a list of experiences that have been published? Basic information about individual experiences such as the author, thingmark association, description, etc? Any guidance would be greatly appreciated! Thanks!
There is a PTC.SCA.SCO.PostgresDatabase Thing on our Thingworx instance. Adding an SQL Query script like below retrieves all projects published to the experience service associated with that Thingworx instance:
SELECT
FROM
idmapping
Posting for posteriority in case any is wondering how this was resolved.
Using https://<ES server url>/ExperienceService/content/projects/ can get a json file that contains Project list and some properties.
https://www.ptc.com/en/support/article/CS281363
https://www.ptc.com/en/support/article/CS299144
https://www.ptc.com/en/support/article/CS330711
SELECT
FROM
idmapping
