I'm trying to build a buttom to open other apps, to be precise, chalk and teams, both are already instaled in the device, a Realwear HMT-1.
I've tried this code for chalk:
$scope.chalk = function ( ) {
try{
window.location.href='https://vuforiachalk.com/';
twx.app.fn.addSnackbarMessage("window.location.href="+window.location.href,"twLogo");
catch(e)
alert('call failed ' + e);
But it takes me to the website, where I'm request to install the app, which is already instaled.
Any advise?
Thanks for your help,
check below link if it may help..
https://community.ptc.com/t5/Vuforia-Studio/open-vuforia-chalk-with-vuforia-studio/td-p/578190
Hello @Suraj_Patil,
I've already tried "vuforiachalk://" way.
Also, PTC recommends to use this deeplink:
But them just does not work. I'm building the experience for "RealwearHMT-1" a 2D eyewear. Also, when I go check admited links to open chalk:
It's empty, so I'm not even sure of the URL to use.
Yes i got it . but i would suggest use vuforia chalk and teams app separately in HMT-realwear-1 instead of including it in vuforia view. Because other apps are hardware related constraints. and in anyways integration all things in view is tedious task. I am also using zoom and teams on HMT realwear-1 that works fine individually. anyways using this voiceover hardwares are a skills to learn and most of the times customers get irritated because of this and screen size is also an issue.
so i would suggest keep it simple.
