I've a top-assembly with five sub-assemblies, which i added into studio as .pvz file. There I want to play with the sub-assemblies individually (example: a button to change the transparency level of one sub-assembly alone), so I dropped the 'model-item' widget on my model. But it picked only one single part. Converting each sub-asembly into individual .pvz will work, but is there any way to pick a sub-assembly after importing the top level as a single model.
Thanks!
In Vuforia Studio, the Model Item has a field named Component Occurence.
With this field we can control which Component of the Assembly to use.
The solution to find quickly, the path of occurrence is to use Creo View and to follow these steps :
In the Model tab, in the tree, select the sub Assembly, Part or Component wanted
Best regards,
Samuel
Best regards,
Samuel
Excellent!!! It worked. Thanks.
