Share input data between view scenes
PabloCastilla
I'm trying to get data from QR codes (string data) using Scan widgwet. It works as it showld in the view scene where was deployed. But what I want to achieve is to share this data between view scenes.
For context, Users have to scan their QR-ID, Need this ID to be shown over all the view Scenes.
I tried with a function:
$scope.view.wdg['label-name1']['text']= $scope.view.wdg['label-name2']['text'];
Also i tried adding "view.(viewname).wdg," But nothing seems to work.
 Thank you.
I found a different way just binding it to an app parameter in different views.
However, thank you.
2 REPLIES 2
To continue,
I bind the scan to a label in home view. I have another label in a different view. What I'm trying is to share the data storaged in the first label to the second.
However, thank you.
