I'm trying to get data from QR codes (string data) using Scan widgwet. It works as it showld in the view scene where was deployed. But what I want to achieve is to share this data between view scenes.
For context, Users have to scan their QR-ID, Need this ID to be shown over all the view Scenes.
I tried with a function:
$scope.view.wdg['label-name1']['text']= $scope.view.wdg['label-name2']['text'];
Also i tried adding "view.(viewname).wdg," But nothing seems to work.
Thank you.
I found a different way just binding it to an app parameter in different views.
However, thank you.
To continue,
I bind the scan to a label in home view. I have another label in a different view. What I'm trying is to share the data storaged in the first label to the second.
However, thank you.
