Specifications for iPad Pro / iPhone (iOS LiDAR) for the best Area Target Generation
I would like to know which iPad/iPhone is the best for creating Area Targets. Maybe PTC or a community member has done such testing.
- Does a device with the latest processor and more RAM and storage allow for a larger area to be scanned or a better quality scan to be created?
- I believe the app will limit the scan to 5 minutes, is this different depending on device specs?
- In the allotted time can I scan as big of an area or as high quality as possible?
Some of the crucial factors as I see them are:
- What is the maximum area size that can be scanned? Does it vary between device specifications? (I found this in the best practices guide: 10 m2 up to 50 m2 or 500 sq ft are best captured with the Vuforia Area Target Creator app, our is that we cannot use the Matterport or other scanners as Matterport is not IP-rated and the others are not supported in Studio, therefore we need to scan as large of a space as possible with iOS.)
- Is there a required storage size per m2 in a target? Or the storage size of a scan using the maximum time allocated.
- What will the quality of the scan be? I will be scanning industrial piping, therefore require high quality/density to capture the detail.
- What is the accuracy of the scan (e.g. 3mm)? The scans are of brownfield projects, there are no 3D models available, therefore we would like it as accurate as possible.
Any advice or assistance would be greatly appreciated.
