Specifying the Respective Sequence for the pvz selected using Drop Down Menu (Dynamic Model Loading)
akanoo
8-Gravel
I have uploaded few pvz files in Thingworxs studio resources and I am calling them using Drop Down Menu (Dynamic Model Loading) method.  Each pvz file has a sequence of its own.
Is there a way to load the respective sequence when the particular pvz is selected in the drop-down menu.
tmccombie
(To:akanoo)
Check out this community post that discusses using multiple sequences. You should be able to implement one of these ideas for your use case.
https://community.ptc.com/t5/ThingWorx-Studio/Can-t-use-more-than-one-sequence-animation-in-a-single/m-p/518235
