I have uploaded few pvz files in Thingworxs studio resources and I am calling them using Drop Down Menu (Dynamic Model Loading) method. Each pvz file has a sequence of its own.
Is there a way to load the respective sequence when the particular pvz is selected in the drop-down menu.
Check out this community post that discusses using multiple sequences. You should be able to implement one of these ideas for your use case.
