Unable to execute the service from thingworx to Vuforia Studio
MA8731174
Can anyone please look at it as i want to execute this service from RESOURCES in vuforia studio but i am unable to execute it. Request is not going.
  $timeout(() => {
    twx.app.fn.triggerDataService("CurrentSessionInfo", "GetCurrentUserExtensionProperties");
  }, 100);
     $scope.$on("GetCurrentUserExtensionProperties.serviceInvokeComplete", function (evt, arg) {
    let result = $scope.app.mdl["CurrentSessionInfo"].svc["GetCurrentUserExtensionProperties"].data;
    console.log("Jamal Ashraf"+result);
 /*   var userNames = [];
    for (var i = 0; i < result.array.length; i++) {
      userNames.push({ "value": result.array[i].value });
      console.log(result.array[i].value);
   // $scope.view.wdg["select-1"].list = userNames;
MA8731174
(To:MA8731174)
I got the solution but thats strange because service itself does not have any parameter in thingworx but it needs parameter to run as below you can see:
 var params = {"type":"Things"};
    twx.app.fn.triggerDataService("CurrentSessionInfo", "GetCurrentUserExtensionProperties",params);
  }, 100);
now it is working fine as expected.
    let result = $scope.app.mdl["CurrentSessionInfo"].svc["GetCurrentUserExtensionProperties"].data.current.description;
    $scope.app.params.userName=result;
    console.log("The user"+ result +" is loggedIn!");
MA8731174
(To:MA8731174)
  }, 100);
sure that empty param will not work? - so at least it should be a json when ever it could be empty when not arugment required
var params = {};
 - so think issue form Vuforia side not form thingworx
