Oct 1, 2018 7:17 AM UTC
Using Next and Previous Buttons for Popup visibility
I want to change the popup on the click of the next and the previous button.For example: If I am on the first popup/panel and when I click on previous then it will not work and when I click on next then it will go the second popup and similarly to the third and consecutive popups and when I am on the last popup and click on the next then it must give me message and when I click on previous pages from either of the pages or from the last popup it will perform accordingly.Here is my code snippet.Please help me in performing the same functionality.
Thanks & regards,
Swapnil More
$scope.getPrev = function() {
if ($scope.app.params.panelVisible > 0) {
$scope.app.params.panelVisible --;
$scope.getNext = function() {
if ($scope.app.params.panelVisible < 2) {
$scope.app.params.panelVisible ++;
dongxfAnswer
7-Bedrock
Oct 17, 2018 1:22 PM UTC
Attached is the project.
Oct 3, 2018 4:09 PM UTC
Hi Swapnil More,
One way to implement this scenario is as follows:
  • In the Data panel, add application parameters such as popup1, popup2, popup3 and so on as per your requirement.
  • Bind the popup1 application parameter to the visible property of popup-1 widget.
  • Bind the popup2 application parameter to the visible property of popup-2 widget.
  • Repeat the same for remaining popup widgets.
  • Drag and drop 2 label widgets on to the 2D canvas. Uncheck the visible property and enter the desired inputs in the text fields of the label widgets. For example,
    • In the label-1 enter "No previous popups available. Please click Next button"
    • In the label-2 enter "No next popups available. Please click previous button"
  • Add two application parameters such as PreviousLabel and LastLabel. Bind these two parameters to the visible property of the label widgets respectively
  • Now write the js function for navigating through the popup widgets with Next and previous buttons. Below is the sample code for navigating among 3 popup widgets
    • $scope.nextPopup = function()
      if($scope.app.params.nextPopup == 0)
      $scope.app.params.PreviousLabel = false;
      $scope.app.params.popup1 = true;
      $scope.app.params.nextPopup = 1;
      else if($scope.app.params.nextPopup == 1)
      $scope.app.params.popup1 = false;
      $scope.app.params.popup2 = true;
      $scope.app.params.nextPopup = 2;
      else if($scope.app.params.nextPopup == 2)
      $scope.app.params.popup2 = false;
      $scope.app.params.popup3 = true;
      $scope.app.params.nextPopup = 3;
      else if($scope.app.params.nextPopup == 3)
      $scope.app.params.popup3 = false;
      $scope.app.params.LastLabel = true;
      $scope.previousPopup = function()
      $scope.app.params.LastLabel = false;
      $scope.app.params.PreviousLabel = true;
      $scope.app.params.nextPopup = 0;
      else if($scope.app.params.nextPopup == 0)
  •  Drag and drop 2 buttons and name them as 'Next' and 'Previous'.
  • In the click event of button 'Next' call the nextPopup(); function
  • In the click event of button 'Previous' call the  previousPopup; function
  • Save and test the experience.
Hope this helps!
Oct 4, 2018 5:58 AM UTC
I tried this code as you told me but it's not working actually i tried same one before few days but it doesn't work
if you have any other way pl. tell me.
