Using Next and Previous Buttons for Popup visibility
Swapnil_More
I want to change the popup on the click of the next and the previous button.For example: If I am on the first popup/panel and when I click on previous then it will not work and when I click on next then it will go the second popup and similarly to the third and consecutive popups and when I am on the last popup and click on the next then it must give me message and when I click on previous pages from either of the pages or from the last popup it will perform accordingly.Here is my code snippet.Please help me in performing the same functionality.
Thanks & regards,
Swapnil More
$scope.getPrev = function() {
if ($scope.app.params.panelVisible > 0) {
$scope.app.params.panelVisible --;
$scope.getNext = function() {
if ($scope.app.params.panelVisible < 2) {
$scope.app.params.panelVisible ++;
Swapnil More
Attached is the project.
10 REPLIES 10
Hi Swapnil More,
One way to implement this scenario is as follows:
  • In the Data panel, add application parameters such as popup1, popup2, popup3 and so on as per your requirement.
  • Bind the popup1 application parameter to the visible property of popup-1 widget.
  • Bind the popup2 application parameter to the visible property of popup-2 widget.
  • Repeat the same for remaining popup widgets.
  • Drag and drop 2 label widgets on to the 2D canvas. Uncheck the visible property and enter the desired inputs in the text fields of the label widgets. For example,
    • In the label-1 enter "No previous popups available. Please click Next button"
    • In the label-2 enter "No next popups available. Please click previous button"
  • Add two application parameters such as PreviousLabel and LastLabel. Bind these two parameters to the visible property of the label widgets respectively
  • Now write the js function for navigating through the popup widgets with Next and previous buttons. Below is the sample code for navigating among 3 popup widgets
    • $scope.nextPopup = function()
      if($scope.app.params.nextPopup == 0)
      $scope.app.params.PreviousLabel = false;
      $scope.app.params.popup1 = true;
      $scope.app.params.nextPopup = 1;
      else if($scope.app.params.nextPopup == 1)
      $scope.app.params.popup1 = false;
      $scope.app.params.popup2 = true;
      $scope.app.params.nextPopup = 2;
      else if($scope.app.params.nextPopup == 2)
      $scope.app.params.popup2 = false;
      $scope.app.params.popup3 = true;
      $scope.app.params.nextPopup = 3;
      else if($scope.app.params.nextPopup == 3)
      $scope.app.params.popup3 = false;
      $scope.app.params.LastLabel = true;
      $scope.previousPopup = function()
      $scope.app.params.LastLabel = false;
      $scope.app.params.PreviousLabel = true;
      $scope.app.params.nextPopup = 0;
      else if($scope.app.params.nextPopup == 0)
  •  Drag and drop 2 buttons and name them as 'Next' and 'Previous'.
  • In the click event of button 'Next' call the nextPopup(); function
  • In the click event of button 'Previous' call the  previousPopup; function
  • Save and test the experience.
Hope this helps!
Swapnil_More
(To:ytella)
I tried this code as you told me but it's not working actually i tried same one before few days but it doesn't work
if you have any other way pl. tell me.
Swapnil More
Swapnil_More
(To:ytella)
Can you help me with this once
Swapnil More
Is this what you are looking for?
dongxf
7-Bedrock
(To:dongxf)
 Please ignore the video I uploaded on 10/12.
Here is the video I intended to upload.
Swapnil_More
(To:dongxf)
I know this method but this method not useful in Realwear HMT 1.
If you can do it with single Next and Previous buttons then tell me.
Swapnil More
Is this what you need?
Swapnil_More
(To:dongxf)
Can you send me JS code use for that ?
Swapnil More
Swapnil_More
(To:dongxf)
Swapnil More
