Vuforia Studio Error On Startup
bkenney10
3-Newcomer
I installed Studio on my computer. When I start it up, it opens but I get "Error Occurred, check log".
Also, when I click on publish, it says: "Localhost:3000 says missing required information".
Finally, when I click My Thingmarks per instructions in a tutorial, studio tells me: "To retrieve your ThingMarks from the developer portal, click here". I click the link, enter my developer account information (verified) and it says: "Auto configure failed. Check log for details.
Any help would be appreciated. Thanks!!
I attached the log...
6 REPLIES 6
Are you using the trial or a commercial version of Studio?
The Trial Version
Is there a solution to this issue?  Im having the same problem.  Just started my free trial version and cant even get out the gate.
I'm having the same issue. It's been a pretty rough start and haven't started. BTW: Using a Mac.
Same 😞
HI @chuongpqvn. Check out our knowledge article on this issue here. It's most likely a network issue. The easiest workaround is to try the auto-configuration on an open network. If you're still running into issues, please provide your Studio log file.
