TML widget X-ray shader
hi there,
I tried to apply x-ray shader on model Item with TML widget
<script name="xray_green" type="x-shader/x-fragment">
precision mediump float;
varying vec3 I;
varying vec3 N;
const float edgeFalloff = 1.0;
const float intensity = 1.0;
const float ambient = 0.2;
void main() {
vec4 color = vec4(0.1,0.9,0.3,1.0);
float opacity = abs(dot(normalize(-N), normalize(-I)));
opacity = ambient + intensity*(1.0-pow(opacity,edgeFalloff));
gl_FragColor = opacity * color;
gl_FragColor.a = opacity;
</script>
<script name="xray_green" type="x-shader/x-vertex">
attribute vec3 vertexPosition;
attribute vec3 vertexNormal;
varying vec3 I;
varying vec3 N;
uniform mat4 modelViewProjectionMatrix;
uniform mat4 modelViewMatrix;
uniform mat4 normalMatrix;
void main() {
vec4 vp4 = vec4(vertexPosition,1.0);
vec4 P = modelViewMatrix * vp4;
I = P.xyz - vec3(0);
N = vec3(normalMatrix * vec4(vertexNormal,0.0));
gl_Position = modelViewProjectionMatrix * vp4;
</script>
and the result looks like
How do I get the details like this? https://www.youtube.com/watch?v=0UJt9mYSSis
Especially the surfaces inside the structure.
Any feedback would be appreciated. ![]()
ClarK
