When i tried my program to publsih on the test server it works, but on the server from my univeristy not.
I set the experience server correctly but when ich try to share the programm i get following error in the protocol pf vuforia studio:
2019-03-07T11:37:01.500Z] error: [twx-studio:tgt-gen.img] Response code 403
[2019-03-07T11:37:01.500Z] error: [twx-studio:tgt-gen.img] Could not retrieve signature, {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2019-03-07T11:37:01.500Z] error: [twx-studio:tgt-gen.img] Failed to generate the data set for model VuforiaStudio\Projects\NEw_Dectection_mitDH_late\dist\app\resources\Uploaded\bearbeitetohne Werkzeug.pvz undefined
[2019-03-07T11:37:01.501Z] error: [twx-studio:projectHelper] publishTask error for project NEw_Dectection_mitDH_late { Error: Publish failed, issue generating model target information
at _Error (VuforiaStudio\studio-download.vuforia.io\node_modules\target-generator\lib\modelTargets.js:25:17)
at ModelTargetGenerator.generateDataSet (VuforiaStudio\studio-download.vuforia.io\node_modules\target-generator\lib\modelTargets.js:204:13)
at process._tickCallback (internal/process/next_tick.js:68:7) i18n: true }
[2019-03-07T11:37:01.501Z] error: [twx-studio:api] Error occured while publishing project NEw_Dectection_mitDH_late { Error: Publish failed, issue generating model target information
I hope someone can help me with this thanks
I found more details in this article;
https://www.ptc.com/en/support/article?n=CS279248
Model Target should be supporter for On-Premise Vuforia Experience Service since 8.3.4.
But, in configuration.json file, the mth.disable should be set to false.
Best regards,
Samuel
Hello Milliau,
The error messages seem very similar to this thread :
https://community.ptc.com/t5/Studio/can-not-publish-experience-with-model-target/td-p/536438
On the Vuforia Experience Service from your university might be in an old version where Model Target is not supported.
Best regards,
Samuel
Hello Samuel,
thanks your your answer. It should be the version 8.3.8 is there somewhere an information which version give support for model target tracking?
Milieu
Best regards,
Samuel
