Vuforia View - Error in Live Data (Thingworx/Sensor)
Swapnil_More
Hello Sir/Madam,
I created one Experience In which I bound data to label in preview it shows value but in IPAD it shows only "Label" text. (same thing happening with Gauge widget).
As well as when I am enable state definition to Gauge widget It shows only color (no value).
Could anyone explain me this behavior of Vuforia View?
Swapnil More
Hi @Swapnil_More,
Could you please assign the Run time permissions for the es-public-access user to the properties, events and services of the entity whose data must be accessed by a public experience.
  1. From ThingWorx composer, open the entity whose data must be accessed by a public experience
  2. Click the Permissions icon in the last column of the row containing the entity
  3. Click Run Time under Permissions
  4. Under All Properties, Events, Services, use the search box to find and add the es-public-access user
  5. Click green dot under the appropriate permissions columns2.JPGClick Save
3 REPLIES 3
Hi @Swapnil_More,
Swapnil_More
(To:ytella)
Thanks for Help!!!
Swapnil More
I have read this post and this can may be helpful for my problem also...
i am having issue that i have thing in thingworx and i update the property with service and then DataChange event i use in vuforia studio to do some task (with Datachange event i execute another service in vuforia studio). It works completely fine with my admin user but not with user of customer means composer user which has all rights i have assigned. would you please give you some insights..?
here is my post
https://community.ptc.com/t5/ThingWorx-Developers/DataChange-Event-not-triggering-for-non-admin-user/m-p/1038046#M70690
