As soon as I start a sequence in view the app crashes occasionally.
The behavior only occurs when it comes to a specific model. It does not on other models.
These are the last lines from the log file:
promiseReactionJob@[native code]
2021-06-11 08:54:33.815 ThingBrowser[ (I removed this part for publication) ] playStep name=model-1
libc++abi: terminating with uncaught exception of type cvu::bad_variant_access: bad_variant_access
Ipad: Ipad Pro (11 inch, 3rd generation).
Vuforia View and Vuforia Studio are up to date.
i need a solution for a customer quickly please.
Hello Lucas,
It seems an issue specific to iOS and to a specific PVZ file.
I have some questions to have a better understaning :
Here, the error message seems occured in a C++ library named libc+abi.
Previously, another crash in iOS with a different error message but in the same library has been reported to R&D.
More details in this article :
https://www.ptc.com/en/support/article/CS322963
It was reported in Vuforia View 8.5.6 and corrected in next release in Vuforia View 8.5.7.
The error message cvu::bad_variant_access: bad_variant_access is unknow in PTC Technical Support database.
I suppose that this data cannot be shared in a public area as this forum.
So for a deeper analysis, I would recommend to open a case at Technical Support with the Project folder and the pvz file.
If the issue is reproducible in house at PTC (and I guess it will).
Investigation will focus on the Sequence made in Creo Illustrate. What are the effects applied in Creo Illustrate ..etc... ?
If the issue is reproducible and investigation about Sequence doesn't help to find a root cause, it will be needed to report that to R&D for a deeper analysis and I suppose a fix.
Of course, I cannot garantee that it will be fixed in next release as previously but it is the only solution we have to solve this problem.
Best regards,
Samuel
