disable popup after clicking previous button
AS_9962540
7-Bedrock
I have added a popup at the end of the steps using stepcompleted event and I want to disable the popup when I click previous button as it is still showing after clicking the previous button. How can I do that?
2 REPLIES 2
please check this may help. here user has used the JS for showing instructions at every step, Instead of that you can used hide /show js script for popup.
what you can do is make pop up widget false in every step except last step.  I think this may work. let me know the feedback.
$scope.view.wdg['pop-up'].visible = false;
https://community.ptc.com/t5/Vuforia-Studio/Add-text-to-AR-steps-in-popup-window/m-p/569430#M4066
I am using below code for the previous button. I tried this code but it didn't work.
$scope.rewindStep = function() {
// rewind the step
$scope.app.fn.triggerWidgetService("model-1", "rewind");
// make sure play button is visible in case they rewind the last step
setTimeout(()=>{ $scope.$apply(()=>{$scope.setWidgetProp("button-2","visible",true);}); console.log("setting playbutton to visible"); }, 100);
setTimeout(()=>{ $scope.$apply(()=>{$scope.setWidgetProp("label-6","visible",true);}); console.log("setting playbutton to visible"); }, 100);
