fill select widget with for loop
GianVal
I want to fill the
$scope.view.wdg["select-1"].list
with a for loop.
just like i can do with the following method.
var title = []; for(var i = 0; i < array.length; i++) { title[i] = { name: array[i], value: i+1 }; }
How can I do?
both approaches are working and your code show work - not sure what is not working for you
$scope.colors = function () {
        var listOfColors = [
              {display: "Red",value: "red"},
              {display: "Green",value: "green"},
              {display: "Blue",value: "blue"}
        $scope.view.wdg.colorSelector.list = title;
$scope.$on("$ionicView.afterEnter", function (event) {
$scope.view.wdg["colorSelector"].list = title;
// or
$scope.$on('modelLoaded', function (evt, arg) {
     $scope.colors();
2 REPLIES 2
sebben
(To:GianVal)
you can do it like this:
var array = ["a","b","c"]
var title = [];
{ title[i] = { display: array[i], value: i+1 }; }
$scope.view.wdg["select-1"].list = title;
// or
     $scope.colors();
