how I can make a dropdown list for multiple views within the same project.
IB_10645210
Hello Roland @RolandRaytchev
Could you please advise how I can make a dropdown list for multiple views (within the same project).
I have a list of Views (30) that I want to be nested in a dropdown list.
Thank you!
Continuation to topic
@RolandRaytchev
Hi, unfortunately, this solution didn't work.  I have checked the bindings but I can't see the issue.
Please advise/suggest a solution.
11 REPLIES 11
Hi @IB_10645210 ,
unfortunately I do not know how to get a list of all views by default functionality. What is possibly working is to find how many views are there defined by the project by calling something like this
$scope.$on('$ionicView.afterEnter', function() {
if ($rootScope.$$listenerCount['$ionicView.afterEnter']>1) {
let num_views=$rootScope.$$listenerCount['$ionicView.afterEnter']
 console.info("We have more then one views = "+num_views)
so we can know how many views are defined in the vuforia Stuido project  but unfortunately I could not find a way to get a list of this views whiteout any preparations
What could be a possible preparation. One json file which contains the list of all defined views is this one: 'appConfig.json' which is located in the root Vuforia Studio project folder. So possibly when in a project I finished the definition of views , so I could copy this file to the upload folder and then could use some code like this:
$scope.loadFile('appConfig.json');
where the $scope.loadFile() is defined as (also other auxiliary functions)  :
$scope.loadFile = function(my_file){
   var nameFile = "app/resources/Uploaded/" + my_file;
    var xmlhttp = new XMLHttpRequest();
    xmlhttp.open("GET", nameFile, true);
    xmlhttp.responseType = "blob";
    xmlhttp.onload = function() {
        var fileReader = new FileReader();
        fileReader.onload = function() {
           var myFile = this.result;
            $scope.myFile=JSON.parse(myFile);//save to scope
          $scope.ViewsArray=JSON.parse(myFile).targets.phone.components;
          $scope.JsonListViews=[]
          for(var ob in $scope.ViewsArray)
           let item = $scope.ViewsArray[ob]
          let my_lst_item=new List_items("ViewName:"+item.name+"<>viewType:"+item.viewType,item.name)
          $scope.JsonListViews.push(JSON.parse(JSON.stringify(my_lst_item)))
          $scope.app.params.ViewList=$scope.JsonListViews;
          $scope.$applyAsync();
        fileReader.readAsText(xmlhttp.response);
    xmlhttp.send();
// this the object for the filling the list
function List_items(display,value) {
  this.display = display;
  this.value = value;
  return this;}
$scope.clickList= function(wdgName){
//this is the function for the click on the list to navigate to view
let view = $scope.getWidgetProp(wdgName,'value')
$scope.navigate(view)
So the mentioned functions will read the json file and create a list with the views and set it to a app parameter which could be linked to any list widget in any views. Here example for this :
Here attached the demo project where I tested this: DynModelChangeUIcommunity_new.zip
Thank you so much!
That is great!  Thank you so much for the detailed instructions, it helps a lot.
@RolandRaytchev
Could you please advise how I can minimize the view names in a dropdown list?
Example: "ViewName: Home<>viewType: ar"  -----to---> "Home"
Hi @IB_10645210 ,
yes this is easy - I wanted only to provide more information but we can reduce then the part :
by
          let my_lst_item=new List_items(item.name,item.name)
Thank you!
@RolandRaytchev
Could you please advise what I might miss?
My dropdown shows the list but doesn't open the selected views.
My code:
this.value = value;
return this;}
xmlhttp.send();
I have tried to analyze code from your example, but didn't succeed.
Not sure , but possibly the usage of this code and the setting in the UI:
The code above  should navigate when you select the value: please, check the select widget name and the correct setting in the value in the Value changed UI Js
I hope this will help, if not then, please, let me know
@RolandRaytchev
@RolandRaytchev  Nevermind, the semicolon was my issue.
Everything works 🙂
Thank you!!!!
