how do i set a timer
benchan95
6-Contributor
Hi all,
I am currently developing a project that requires a timer in the UI. Which means, once the experience is launch, the timer will automatically start. This is to track the amount of time needed for the technician to finish the task. But how do i code this function to the value?
Hi @benchan95 , @
I think you can find directly information for one possible solution in the current Vurofia Studio  help center - following link:
Use a Timer in JavaScript
Hi @benchan95 , @
Hi Roland,
Problem is solved. Thank you!
