Hi, i created a Three of sequence.
but ThingWorx studio can select one sequence
I want to change a sequence via button or list
how can i change sequence at running app
Thank you
Here is my suggestion:
Add the following JavaScript code:
$scope.FirstSequence = function() {
$scope.view.wdg['model-1']['sequence'] = 'l-Creo%203D%20-%20Figure%201.pvi';
$scope.$applyAsync();
$timeout(function() {
$scope.$broadcast('app.view["model-1"].svc.playAll')
}, 400)
$scope.SecondSequence = function() {
$scope.view.wdg['model-1']['sequence'] = 'l-Creo%203D%20-%20Figure%202.pvi';
}, 400)
$scope.ThirdSequence = function() {
$scope.view.wdg['model-1']['sequence'] = 'l-Creo%203D%20-%20Figure%203.pvi';
}, 400)
FirstSequence();
}, 400)
Best of luck,
Ricardo
}, 400)
}, 400)
}, 400)
FirstSequence();
}, 400)
Best of luck,
Ricardo
Any Examble project is there for reference.
