how to comment widgets in Vuforia Studio
MA8731174
Hello member,
   I have two views in my app called HOME AND START UP. now in Home view i have 8 popups and each pop up contains a lot of widgets and thats why its so hard for me to add or remove widgets in there. I would like to comment from popup 2 till popup 8 so that all my widgets inside would be comments it dows or i cannot see in the vuforia studio so that i can easily and quickly work on the project. As you can see in the attached picture Home.json when i comment the code from popup 2 till popup 8 and then i start the vuforia studio again then the code just appears back. anyone has an idea how to remove the existing widgets and then take them back again. please let me know about it.
Hi @MA8731174,
- better is to check the folder   ...VuforiaStudio\Projects\<Your-Project-Name>\src\phone\components
the dist folder will be updated when there are changes in the src folder- on preview or publish
- the relevant files are
ViewName.js and ViewName.json for each View defined on your project
example:
Home.js and Home.json
The  Home.js contains the javascripts defined and used in this specific view e.g. Home
The widgit defintion is contained by the Home.json file
As mentioned you need only the check the src for the current availible widgets because this will override all that what is in the dist folder. OK when you have started Studion in UI and change in the same time the Home.json and then save the View in the UI , possibly this will override the file. But when you change the src folder and then open the projec it will display the current content of the Home.js and Home.json
Hi @MA8731174,
example:
