multiple thingmark/qr codes same experience
GianVal
Hello, I would like to create an experience able to contain multiple thingmarks at the same time (or to make a succession of different experiences as seamlessly as possible). Let me explain: during the navigation, I would like that, by pointing to a thingmark, some information would come out; if I point to another thingmark, different information and so on.
it's possible?
sebben
(To:GianVal)
You just write something like this:
$scope.$on("trackingacquired",function (evt, data){
  if(data =="38861:1"){
    $scope.view.wdg["label-1"].text= "Information A"
  else if(data =="38861:2"){
    $scope.view.wdg["label-1"].text= "Information B"
Change the ID  to your thingmark IDs and you should see "Information A or B " in the label von you point  to different thingmarks. Note that you need a thingmark target in your experience.
sebben
(To:GianVal)
yes you can use this:
$scope.$on("trackingacquired",function (evt, data){});
The 'data' will contain the thingmark ID which when you point to different thingmarks. You can use it to show different information.
GianVal
(To:sebben)
Sorry, can you better explain the method?
sebben
(To:GianVal)
GianVal
(To:sebben)
I set up a simple exp with thingmark without associating any. when the target is acquired the label does not change its text.
what am I missing?
sebben
(To:GianVal)
It works for me... Did you change the thingmark IDs?
You could share your smaple experience and I can take a look.
