Hello, I would like to create an experience able to contain multiple thingmarks at the same time (or to make a succession of different experiences as seamlessly as possible). Let me explain: during the navigation, I would like that, by pointing to a thingmark, some information would come out; if I point to another thingmark, different information and so on.
it's possible?
You just write something like this:
$scope.$on("trackingacquired",function (evt, data){
if(data =="38861:1"){
$scope.view.wdg["label-1"].text= "Information A"
else if(data =="38861:2"){
$scope.view.wdg["label-1"].text= "Information B"
);Change the ID to your thingmark IDs and you should see "Information A or B " in the label von you point to different thingmarks. Note that you need a thingmark target in your experience.
yes you can use this:
$scope.$on("trackingacquired",function (evt, data){});
The 'data' will contain the thingmark ID which when you point to different thingmarks. You can use it to show different information.
Sorry, can you better explain the method?
I set up a simple exp with thingmark without associating any. when the target is acquired the label does not change its text.
what am I missing?
It works for me... Did you change the thingmark IDs?
You could share your smaple experience and I can take a look.
