problem with load of xlsx file
  • January 21, 2021
  • 1015 views
Hi everyone,
in my project I want to load information from an xls or xlsx file.
My idea is to:
1. load xlxs/xls file
2. convert to json file
3. use the json
I tried to setup this piece of code, that is actually running for *.txt or *.json file:
//\\ ** CARICAMENTO LISTA RICAMBI ** //\\
$scope.app.cad.loadXLSfile=function(fileName){
var xmlhttp = new XMLHttpRequest(); //apertura del file sequenze
xmlhttp.onreadystatechange = function() {
	if (this.readyState == 4 && this.status == 200) {
 	console.log(">> this: "+ this)
 	listaRicambi = JSON.parse(this.response)
 console.log(listaRicambi) // repair_sequence è il nome dell'oggetto indicato nel file .txt formattato con grammatica json
xmlhttp.open("GET", "app/resources/Uploaded/" + fileName + ".xlsx", true);
xmlhttp.send();
So, when I inspect the preview mode console print some error like:
Uncaught SyntaxError: Unexpected token P in JSON at position 0
 at JSON.parse (<anonymous>)
 at XMLHttpRequest.xmlhttp.onreadystatechange (app.js?v1611219048987:568)
Any idea?
Thank you so much.
I think the approach as your tried is good, but I suspect it  will not work in this case.
If you mean xlsx file - is an EXCEL file - I do not think that we could parse this with the basic javaScript functionality e.g. JSON.parse(). So far I know this file is binary so that I do not know such parser could be used . Such parser should "understand" the excel functionality.(in generally could be possible)
What you can do : you can try to export your excel file to csv file and then try to convert the csv format – in case that this is some table values.
Also excel may be, could support some xml export format where you can find some existing xml parse to json.
