question about $interval.cancel
ZL_9884170
Hi All,
I want to achieve such an effect through $interval: when I click button A, Call function GunTongstartRotate, the model starts to rotate continuously; when I click button B,Call function GunTongstopRotate, the model stops rotating. The following is the code I wrote.
$scope.GunTongRotate = function() {
		$scope.app.params.QMJrx = $scope.app.params.QMJrx-5;
$scope.GunTongstartRotate = function() {
        //store the interval promise
       $scope.app.params.QMJrx=0;
		 intervalPromise = $interval($scope.GunTongRotate, 50, 0);
$scope.GunTongstopRotate = function() {
  if(angular.isDefined(intervalPromise)){
    $interval.cancel(intervalPromise);
The problem is that when I click button A multiple times, the model will turn faster and faster, and clicking button B again will not stop the model from turning. How should I solve this problem?
sebben
(To:ZL_9884170)
you can  check if the model is already rotating like this:
var isRotating = 0;
  if(isRotating==0){
    isRotating = 1;
    isRotating = 0;
sebben
(To:ZL_9884170)
var isRotating = 0;
  if(isRotating==0){
    isRotating = 1;
    isRotating = 0;
ZL_9884170
(To:sebben)
Hi sebben,
Thank you for your reply! Your idea is very clever, but unfortunately, the problem still remains that when I click the start rotation button many times, the model still spins faster and faster, and clicking the Stop button doesn't work.
sebben
(To:ZL_9884170)
That's odd, it works for me. Did you copy and paste the code or did you edit your code?
ZL_9884170
(To:sebben)
Thanks ! I reviewed the code and found a spelling mistake. When I corrected the spelling mistake, the problem was solved!
