"Mechanism" on an assembly on Creo
Wind_install
If I do a "mechanism" on an assembly on Creo. Can I use the "mechanism" on Thingworx Studio?
I have tried this, as far I understand no, not yet. One would need to be able to import the .fra file to the sequence in Creo Illustrate, right now you can only import to the animation in Creo Illustrate, which can not be imported to Studio. I hope that it is a feature coming soon either directly in Studio or in Illustrate.
