This widget could not be displayed.
thingworx studio stop working
fbenjamin
I have been using ThingWorx Studio for around a week, it stopped working for what every reason. so i am trying to reinstall it. I seem to been having a problem reinstalling it.
Application cannot be started contact the application vendor. attached is the log file can any one help i was doing so well!
Message was edited by: Sushant Pandey moved to ThingWorx Studio Community
8 REPLIES 8
What happens if you download the URL in the log (via the browser) and install it via this file?
https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
You can also check out this article... it mentions some of the directories where (temp) files might be stored - maybe they are interfering with the new installation, so be sure to clean those directories out after de-installing Studio.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS251716
Hi Michael, I have tried using the link I seem to get the same problem as before.
Hi FITZ BENJAMIN​, Could you please share the steps followed to reinstall ThingWorx Studio.
From the logs it seems that some file cannot be found and the activation failed.
I would recommend you to restart the Server after the uninstall.
Ankit Gupta
Hi Gupta;
I have followed the details for uninstalling ThingWorx information
emoved the ThingWorx folder from within document
  1. I also within user Users\myname\AppData\Roaming
  2. Restarted
  3. Tried to install again and I get the same problem
  4. I have also tried the URL Link
I have attached the install log file
Any ideas?
Microsoft .NET Framework 4.5.2 is installed correctly?
(as it says "no install needed" I'd guess it is, but a confirmation on this will be helpful)
Update:
The current status of my problem.
  1. After trying all the posted recommended work a round’s which need not same to resolve the problem
  2. I made a discsion to rebuild mypersonal computer from the OS upwards and reinstall my application, it was running a bit slow anyways
  3. I then reinstalled ThingWorx Studio, it worked first time round without any problems.
Device Type :
  1. Windows 7 pro
  2. Service pack 1
Regards
FB
Hi
Has anyone solved this problem? I am getting similar problem. Studio working fine on Windows 10 and then it stopped working. That is the application launches correctly but then when I click to open (localhost), i get spining thingmark logo and waits forever.
I tried uninstall and reinstall Studio and same problem.
Any help appreciated.
Go to %userprofile%\AppData\Local\Apps and delete the 2.0 file. Reinstall the setup file and you will have access again.
Good luck,
Sabrina.
