Hello all,
the coloring of parts using the renderer doesn't work properly with vuforia version 9.3.1
Sometimes clicking on parts will do nothing at all, sometimes after clicking 3 times, the part changes color. It doesn't work properly in the preview and also not in vuforia view 9.3.1
Anyone else having this issue?
try{tml3dRenderer.setColor($scope.currentSelection, PICK_COLOR);}
catch (ex) {console.warn("Exception 1 in tml3dRenderer.setColor()=>"+ex);}
How to select model components in a 3d model witho... - PTC Community
Okay, this is really silly, I was able to find the problem. There were several identical objects overlapping each other. It seems like I didn't always click on the most outboard, so an inner one was blinking but I wasn't able to see it.
First, I thought of deleting the post, but then I thought: “Maybe someone is getting tricked into this and finds help here”
Cheers,
Whity
Cheers,
Whity
