Dear Community,
I have customized a Change Notice type and created a custom attribute in this type, this attribute is a drop down box to select the value, in addition I have created a template for change notice based on this type, in the template I have set the value of this attribute, in this case when the user creates a change notification, select the template, the value of this attribute will be brought over, but the user can still select other values
When user creates a change notice, can it be set to read-only by the function of OOTB, or do I have to write a customized Validator? Because we don't want to give the user a choice, just follow the values of the template. Thank you.
Best Regards,
Chason
can you try to set, in order complexity :
visibility from type and attribute manger
visibility using a profile
OIR ,
Hi @Fadel ,
thanks for your quick reply, I tried to set Change Notice Attribute visibility to read only, but when I create change notice, there is no value display, like blow:
you are right ,both type and profile visibility produce the unassigned
I will test OIR later and let you know .
Hi @Fadel ,
Sorry to bother you, did you test with OIR? Or we'll have to customize it to make it happen. Thanks.
BR,
Chason
