Version: Windchill 13.0
Use Case: Copy the values of attributes of a Subtype of a Part into another Subtype
Description:
Is there any API or a short way to copy the values attributes from an existing part which is a subtype (eg- Hardware Part) into a new part which is of another subtype while using an action to create that new part.
Hi @OP_11714882
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
