Getting attribute on WTpart from WTpartUsageLink in a BuisnessAlgorithm
  • December 11, 2025
  • 3 replies
  • 171 views
Version: Windchill 12.1
Use Case: Comparing values between an WTpart attribute and a WTpartUsageLink attribute, in a BuisnessAlgorithm - to use on a calculated value on WTpartUsageLink.
Description:
Following this procedure: Procedure – Using a BusinessAlgorithm in a Calculated Attribute togehter with this knowledge base: New java algorithm for calculated attributes (BusinessAlgorithm) starting Windchill 11.0
We have a calculated value on a WTpartUsageLink. This should compare an attribute from the WTpartUsageLink and the WTpart that it is linked to. The attribute from the WTpartUsageLink can be passed as a variable in the execute statement, but I have a hard time referencing the attribute from the WTpart.
Sample code or a pointer for referencing an attribute in this use case would be very helpfull.
Fadel
December 11, 2025
How about using alias attributes mapping to get the info between parts and usagelinks
https://www.ptc.com/en/support/article/CS245103
Buiꓘa
Hi Fadel
Thanks for the suggestion - Alias have the very annoying caveat that it will fetch info for all iterations of a part, and not just the iteration that is currently chosen in the Config Spec, so it wont work for this specific use case.
Community Moderator
December 16, 2025
Hello @JM_12529808,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
